Aktuelle Zeit: Sa 21. Nov 2026, 23:45
BeitragVerfasst: Mi 5. Aug 2026, 09:20
To provide players with more cost-effective gaming products and services, IGGM platform has officially launched a brand-new points system, designed to let you enjoy a superior shopping experience while spending less!
Below, we break down everything you need to know: how to earn points efficiently, use them for discounts or to redeem exciting rewards, and stack VIP benefits to maximize your savings.
Before Using the Points System - Registration Required
Please note that IGGM's new points system is available only to new-registered and logged-in users. If you haven't registered or logged in yet, you will need to do so to access Check-in and Points pages.
How to Earn Points?
Accumulating points at IGGM is simple and straightforward, primarily through two channels: daily check-ins and order rewards.
1. Daily Check-in
Simply click the "Check In Today" button on the IGGM Check-in Center page to complete your check-in; once the button changes to "️Checked In (Come back tomorrow)," your points have been successfully credited! Alternatively, you can also check in by clicking the current date on the calendar.
One-tap check-in (Easter egg)
There's a little Easter egg here! If you forget to check in for the day and land straight on the coupon redemption page, just tap the "little rocket" emoji at the bottom of the list to check in instantly - no need to navigate back to the Check-in Center. You'll still get those incremental rewards for consecutive check-ins.
Please note the visual differences between PC and mobile versions! For PC users, the small rocket only begins to shake and emit flames when you hover your cursor over it; a single click launches the rocket and credits your check-in points. For mobile users, the rocket icon shakes continuously - simply tap it to check in and earn your points instantly!
Other Check-in Entry
In addition, IGGM provides the following access points for quick and convenient daily check-ins:
1. Click "Go Now" on the coupon redemption page to visit the check-in center.
2. Click the coupon section at the bottom of the homepage to access the check-in center.
3. Click the banner at the bottom of any product page on IGGM to access the check-in center.
Incremental Rewards for Consecutive Check-ins
IGGM's check-in system rewards consistency. If you check in without interruption, your daily points will increase over time: 5 points on the first day, 6 points on the second, and 8 points on the third. From the fourth day onwards, as long as you maintain your streak, you will consistently receive the maximum reward of 10 points per day.
Notes: If you check in via the check-in banner on the product page during your shopping journey, you can return to your original page via Back Shopping at the bottom after completing the check-in and triggering the points accumulation. You don't have to worry about your shopping progress being affected!
Reset Upon Interruption
If you miss a day or break your streak for any reason, your progress will reset to zero. Your next check-in will start back at the Day 1 rate of 5 points. Please note that the daily check-in reset is based on the server's time zone; be sure to check in on time to avoid losing progress due to network issues or other interruptions.
2. Points for Orders
Additionally, whenever you make an order on the IGGM platform, the system will award you points based on your subtotal amount.
Point Accrual Rate: $1 = 1 Point
Under standard conditions, every $1 of your actual spending converts directly into 1 point. To simplify calculations for order amounts involving decimals, IGGM rounds to the nearest whole number when determining the points earned. For example, if you pay $17.35, you receive 17 points; if you pay $34.86, you receive 35 points.
To ensure system efficiency for small transactions, the subtotal amount paid for an order must be at least $1 to trigger point accrual; orders under $1 do not generate any points.
Furthermore, points for all orders will be automatically credited to your account by the system only after the order status has officially changed to "Completed"; the number of points corresponds to the amount of the qualifying purchase.
New User Perk: 10x Point Rewards
IGGM has a welcome gift for new users! Your first paid order on IGGM automatically qualifies for a generous 10x points reward (meaning you earn 10 points for every $1 spent).
Please note the calculation method: the subtotal amount is first rounded to the nearest whole number, and then multiplied by 10 to determine the points for your first order. For example, if your first order's subtotal is $17.35, you will receive 170 points ($17.35 - 17 * 10 = 170 points), rather than multiplying by 10 first and then rounding ($17.35 * 10 = 173.5 - 174 points).
However, if your first order's subtotal is less than $1, you will not receive any points, and your first-order privilege as a new user will be used up. Therefore, IGGM recommends buying higher-value items you need during your first order to make the most of the 10x point reward.
Due to the significant value of this offer, points for the first order will be credited after the order is successfully delivered and passes a security review, provided no refund occurs within 24 hours.
You can view the specific points added upon completion in the My Account - My Orders section of IGGM.com. If you have just completed a payment but do not see the points immediately, please do not worry - simply wait a short while.
Point Value and Validity
Understanding the value of your points helps you make the best use of them. In the IGGM point system, 100 points = $1 (meaning each point is worth approximately $0.01).
Please note that points are not valid indefinitely; each point expires 90 days from the date it was earned. IGGM employs a user-friendly rolling expiration policy: points earned on Day 1 will expire at the end of Day 91. The specific calculation time for rolling expiration depends on the time zone of your account's IP address.
You can check for notifications regarding points nearing expiration on the "My Points" page of your account at any time to ensure you don't miss out on benefits.
Multiple Ways to Use Points: Direct Cash Deduction and Coupon Exchange
When buying items on IGGM, you can choose to use your accumulated points to directly offset the cash cost of your order or exchange them for significant discounts at IGGM Coupon Redemption Center. The choice is entirely yours!
Option A: Direct Cash Deduction at Checkout
On the checkout page, you can use the points in your account balance to reduce the cost of your current order. However, to maintain the integrity of the IGGM points system, the proportion of the order total that can be offset by points is directly linked to your order subtotal.
Please refer to the table below for specific deduction ratios based on order subtotal ranges:
Order Subtotal Range Max Point Deduction Ratio
$1.00 - $9.99 5%
$10.00 - $49.99 8%
$50.00+ 10%
Important notes on using points for cash deductions:
1.Points are awarded only for successfully completed orders; orders that are voluntarily cancelled, flagged for suspected fraud, or fully refunded are not eligible for points;
2.Points for your first order are not credited immediately; they will be issued within 24 hours after successful delivery, provided no refund has occurred;
3.If an order involving points undergoes a partial refund, the system will deduct the corresponding points (rounded based on the refund amount) and return any points that were consumed. Returned Consumed Points = Consumed Points * (Refund Amount / Subtotal Amount);
4.Points can be used in conjunction with VIP discounts;
5.Cannot be used in conjunction with discount codes or cash coupons;
6.Cannot be exchanged for cash;
7.Cannot be withdrawn as cash;
8.Cannot be transferred between accounts;
9.IGGM.com reserves the right of final interpretation for all points-related policies.
Option B: Redeem Discount Codes or Cash Coupons
You can also visit the points redemption page to exchange points (in tiers ranging from 100 to 500 points) for discount codes (various rates) or cash coupons (subject to minimum order requirements). For example, the $10 cash coupon can only be used if your order's subtotal amount is $100 or more. If your subtotal is less than $100, the coupon will not automatically appear at checkout.
Points Spent Discount Code Cash Coupon (Min. Order Req.)
100 3% $1 (Order greater than or equal to $10)
200 4% $3 (Order greater than or equal to $30)
300 5% $5 (Order greater than or equal to $50)
400 8% $8 (Order greater than or equal to $80)
500 10% $10 (Order greater than or equal to $100)
All discount codes and cash coupons are limited to 30 per week, first come, first served! Different colors clearly indicate the current stock status: green for 21-30 remaining, orange for 11-20, and red for 1-10. When stock reaches zero, it will display "Out of stock." But don't worry, just come back next week!
By the way, if you forget to check in for the day, the little rocket emoji on this coupon page is your quick way to do so! With a simple tap, a shake of the little rocket, and your points are in the bag!
While coupons are great, please keep in mind that all discount codes or cash coupons are valid for only 3 days. Redeem them carefully and ensure the items you wish to buy are in stock to avoid wasting your points.
You can view your coupons and their current expiration status on the My Account - My Coupons page.
Note: You can quickly access the coupon redemption page via the "Coupon Center" at the bottom of the IGGM homepage. We recommend bookmarking this page for convenient future check-ins and redemptions - saving you time and effort.
Notes on Points Redemption Coupons:
1.Each reward is limited to the first 30 users per week on a first-come, first-served basis.
2.All discount codes and cash coupons require CF verification upon redemption.
3.Redeemed discount codes/cash coupons are valid for 3 days from the time of claim.
4.Only one discount code/cash coupon can be used per order. They cannot be combined with VIP discounts or points deductions.
5.Discount codes/cash coupons are not valid for gift cards and top-up services.
6.Redeemed discount codes, cash coupons and free orders cannot be returned or exchanged once claimed.
7.IGGM.com reserves the right of final interpretation.
Hidden Option C: Direct Exchange for In-Game Currency/Items (Coming Soon)
In addition to coupons, IGGM will soon add options to the redemption page allowing you to exchange points directly for specific in-game items, such as Monopoly GO cards, Diablo 4 materials, or POE 1/2 currency.
Once you meet the points requirements and click to redeem, a pop-up window will prompt you to enter the necessary delivery details for the game. After accurately filling in the information and completing the verification, the system will automatically generate a free order and display it in Coupon Order list; you just need to wait for it to be delivered safely. More point redemption features and options are coming soon - stay tuned!
If you encounter errors during the redemption verification process, please check your network connection and try again using a reliable VPN.
Furthermore, given the nature of virtual items, returns or exchanges are not possible once an order begins processing; however, if delivery fails due to issues on the IGGM platform, the points used will be fully refunded.
VIP Ranks & Benefits
For VIP members, IGGM offers tiered discounts to all users based on accumulated spending. Once your cumulative spending hits a specific threshold, you automatically unlock a permanent VIP discount:
VIP 1: Your Spending (<$1,000), Get a 1% discount.
VIP 2: Your Spending (greater than or equal to $1,000 and < $3,000) , Get a 2% discount.
VIP 3: Your Spending (greater than or equal to $3,000 and < $6,000), Get a 3% discount.
VIP 4: Your Spending (greater than or equal to $6,000 and < $10,000), Get a 4% discount.
VIP 5: Your Spending (greater than or equal to$10,000), Get a 5% discount.
Discount Stacking Rules:
VIP Discounts CAN be combined with Points Deductions.
VIP Discounts CANNOT be stacked with Discount Codes or Cash Coupons.
At checkout, you may apply either:
Option A: Discount Code or Cash Coupon (Alone)
Option B: VIP Discount + Points Deduction (Note: Discount Codes and Cash Coupons are not valid for Gift Cards or Top-up services.)
Stacking Discounts and Maximizing Savings
How can you get the most savings when checking out? IGGM has designed a smart checkout system based on our VIP ranks and point-redemption rules.
At IGGM, VIP discounts stack perfectly with direct point deductions. However, please note that redeemed discount codes or cash coupons cannot be combined with VIP discounts or point deductions. Additionally, only one coupons may be used per order.
At checkout, the system automatically compares the final costs of "Option 1 (VIP Benefits + Direct Point Deduction)" and "Option 2 (Single Discount Codes or Cash Coupons)" to select the most cost-effective choice for you, saving you the trouble of manual calculations. Which option offers the best deal will be displayed next to that option (Best Value). Of course, if you have your own preferences regarding coupon and point usage, you are free to select your preferred discount method.
Refunds and Point Returns
IGGM's refund policy allows you to request a refund at any time prior to the completion of delivery. However, we have specific rules regarding the refund and rebate of your points in this situation:
Situation 1: Full Refund
If you cancel your order for personal reasons, orders suspected of fraud or requiring a full refund will not be awarded points; furthermore, points already used in such orders will not be refunded.
However, if a full refund is issued due to reasons attributable to IGGM, the points consumed for the order will be fully refunded to your account.
Situation 2: Partial Refund
If an order involving awarded points undergoes a partial refund due to special circumstances, the system will refund a portion of the consumed points on a pro-rata basis relative to the refund amount. Naturally, the points rebate you would have originally received upon order completion will also be adjusted; the corresponding points will be deducted based on the refund amount, with the figure rounded to the nearest whole number.
Here is the formula for calculating point returns during a refund:
Deducted Earned Points = Subtotal Amount - Refund Amount (rounded to the nearest whole number)
The all-new IGGM member point system is designed to offer you more viable discount options for your long-term gaming purchases. Every point accumulated is a sincere token of our appreciation for your support.
Log in to your IGGM account now, visit the Check-in Center to start accumulating points, and experience a smarter, more rewarding checkout process like never before!
Frequently Asked Questions about IGGM Points System
Q1: Can I transfer my VIP 5 perks from my old account to a newly created account and start accumulating check-in points there?
A: No. To ensure account security and platform fairness, VIP tiers and points are treated as exclusive assets of an individual account. According to our system security rules, transferring, merging, or gifting perks across different accounts is strictly unsupported.
Q2: My account currently has 277 points. If I buy items worth $34.68 and use up all my points to get a $2.77 deduction, but later receive a partial refund of $15.44 due to certain factors, how many points will I end up with?
A: Your original $34.68 order generates 35 points based on rounding. Due to the partial refund of $15.44, the system will proportionately deduct 15 points (rounded to the nearest whole number). Therefore, the net points earned from this purchase will be: 35 - 15 = 20 points. Additionally, the system will return the points you consumed. Based on the calculation formula: Consumed Points * (Refund Amount / Total Purchase Amount), you will get back 123 points. As a result, your final account balance will be 123 + 20 = 143 points.
Q3: Can I create unlimited new IGGM accounts and place small orders to exploit the 10x points newcomer reward?
A: No. IGGM strictly prohibits the malicious registration of multiple accounts, utilizing technical exploits, or engaging in order manipulation to farm newcomer benefits. Our system is equipped with rigorous anti-fraud and risk control mechanisms: the 10x points multiplier for the first order will only be credited after the order is successfully delivered and passes a 24-hour anti-abuse system review. If the risk control system detects multi-account farming linked by the same IP, same device, same payment method, or malicious account associations, the platform reserves the right to permanently ban the related accounts and clear all accrued benefits.
Q4: I just registered an account and my first order was a small item for $0.9. Because it was under $1, the system didn't give me any points. Then, my second order was for $100. Why didn't my second order get the 10x points? My first order didn't receive any points anyway, shouldn't this second order count as my actual "valid first order"?
A: No. The system strictly identifies the "New User First Order" based on the very first paid order under your account, regardless of the transaction amount. The threshold ruling out points for subtotals under $1 is a foundational platform policy. Therefore, we highly recommend that new users consolidate their shopping carts on their first purchase and bundle higher-value items into the first order to fully maximize the value of the 10x points perk.
Q5: If a website error prevents me from checking in for the day, causing my check-in streak to break, what measures will IGGM take to compensate for my points loss?
A: We sincerely apologize for any inconvenience caused. The daily check-in resets based on a specific time matching the server's time zone. If the streak is broken due to network latency or missing the refresh window, the system will strictly execute the automatic reset policy. We recommend completing your check-in as early as possible each day and ensuring a stable network environment. If the interruption is conclusively caused by a large-scale server outage on the platform, an official site-wide points compensation announcement will be issued once resolved. Please note that support agents do not have the authorization to manually alter individual check-in histories. Thank you for your understanding.
Q6: I spent 300 points to redeem a $5 cash coupon, but the game items I wanted have been out of stock on the platform for the past few days. As a result, the coupon expired within 3 days without being used. The stockout is the platform's issue, so why should my 300 points be deducted for nothing?
A: We apologize, but once a reward is redeemed at the Rewards Center, the corresponding points will be deducted and cannot be refunded. Because each reward is strictly limited to the first 30 users per week on a first-come, first-served basis, and the cash coupons are valid for 3 days, we highly recommend verifying current product stock and your purchase intent before making a redemption to avoid accidental cash coupon expiration.
Q7: Can I still request a refund if my order status is "Completed"? Can the points be refunded?
A: If IGGM has successfully completed the delivery and you have confirmed the order's completion, we unfortunately cannot honor refund requests. The points spent will not be returned. However, if IGGM fails to complete the service due to our own issues (for example, if Tycoon Racers carry service fails to help you achieve Rank #1), we will refund the points you spent according to the refund ratio.
Q8: Why do I keep encountering errors when trying to redeem a coupon?
A: Coupon redemption errors typically occur due to network instability or system security protocols. Your IP address might be flagged as originating from a high-risk region. We recommend adjusting your VPN settings or connecting to a different network, then trying again. If the issue persists, please reach out to our 24/7 Customer Support team for further assistance.
Q9: Can I use a script or plug-in to claim the weekly limited 30 discount codes/cash coupons available each week?
A: To ensure fairness for all players, we have implemented strict security measures. Redeeming any discount codes or cash coupons requires passing verification, rendering any script-based simulated clicks ineffective. IGGM reserves the right to void coupons and impose account restrictions on any account found using irregular methods (such as multi-instance farming, emulators, or third-party software) to forcibly claim coupons.
Q10: If I use points to offset the cost but later receive a refund due to special circumstances, will the validity period of the returned points be extended?
A: No. Returned points retain their original acquisition date and continue to follow the 90-day expiration rule; the IGGM platform will not reset or extend the expiration date due to a refund. Please use the returned points as soon as possible to avoid expiration!
Diesen Beitrag melden
Mit Zitat antworten
