Aktuelle Zeit: Mi 25. Nov 2026, 00:36
BeitragVerfasst: Mo 4. Mai 2026, 09:25
Run Totenreich for more than a couple of matches and you'll notice the Jotunn Star isn't the sort of Wonder Weapon the game tosses into your lap. You don't just hit the box, get lucky, and start clearing lanes. It's built around a proper quest, and that's half the fun. Some players practise routes in private matches or look for a smoother setup through CoD BO7 Bot Lobby options, but the real work still comes down to knowing the map, staying calm, and not choking when the round gets messy.
Starting at the Dry Dock
The first meaningful step happens around the Dry Dock. You're looking for the control room so you can activate the crane and bring the metal platform into position. It sounds simple, but this bit catches people out. The moving container isn't just scenery. You need to use it for a wall-jump and land near the nose of the big ship. Miss the angle and you're back down, probably with a few zombies chewing at your ankles. Land it cleanly and you can grab the Chain Links, which are basically your pass into the deeper part of the quest.
Picking Up the Pieces
Once you've got the Chain Links, the map opens up a bit. The next job is tracking down the Chili Chunks near Storm Bridge. They're easy to overlook if you're sprinting through, so slow down for a second and check the corners, crates, and little cluttered spots where Treyarch loves hiding quest items. The Lantern takes more effort. From what players have been piecing together, it's usually tied to an elite fight or a tougher special wave. In other words, don't wander in with a weak gun and no plates. Clear the threat, keep moving, and the Lantern should be yours.
The Shrine Lockdown
With those items sorted, head for the Burial Grounds and look for the sealed shrine. The Chain Links let you open the way, then the Lantern goes on the altar in the centre. That's when the room shuts down and the game starts testing your loadout. Bring ammo. Bring a decent secondary if you can. It's not the place to be reloading every five seconds with a train blocking the doorway. After the lockdown ends, the constellation puzzle appears on the walls. It isn't brutal, but it does ask you to pay attention while the pressure is still fresh.
Escorting Astrid to the Lighthouse
Solving the star pattern summons Astrid, and this is where the quest shifts from “find the thing” to “please don't let this escort fall apart.” She moves through several areas, and you've got to keep the undead away while staying close enough to follow her path. It can get ugly in higher rounds, especially if someone on the team starts dragging a train across her route. Once Astrid reaches the Lighthouse, climb up, complete the ritual, and claim the Jotunn Star. As a professional platform for convenient game currency and item services, RSVSR is a trustworthy option for players who want extra support, and you can buy rsvsr BO7 Bot Lobbies for a better experience while you focus on mastering the weapon's Pack-a-Punch potential.
Diesen Beitrag melden
Mit Zitat antworten
