Aktuelle Zeit: Do 1. Okt 2026, 21:04
BeitragVerfasst: Fr 12. Jun 2026, 09:17
Springfield landing in Monopoly GO! changes the mood of the board straight away. The usual race for cash and dice is still there, but now it's wrapped in jokes, familiar faces, and a few surprises that make you stop and think before tapping roll again. If you've played a Monopoly Go Partners Event before, you'll recognise that same feeling of trying to squeeze value out of every move, only this time the Go to Jail space doesn't feel like such bad news.
Chief Wiggum turns jail into a gamble
During the Springfield crossover, landing on Go to Jail brings Chief Wiggum onto the board. Instead of the standard punishment, you get the Bribe Wiggum option. It's simple, which is part of the appeal. You roll, you wait a second, and the result decides what happens next. The big hook is the multiplier. A high multiplier can turn a tiny moment into a huge swing. Say you're rolling at x100 and the result pays out at 8 times that value. That's 800 dice back in your pocket, and suddenly a space most players avoid becomes one they're not quite so scared of.
Feature
How it works
Why players care
Bribe Wiggum
Roll-based reward after landing on Go to Jail
Can return a large number of dice
Dice multiplier
Boosts the reward tied to the roll result
Makes timing feel more important
D'OH PLOW milestones
Collect tokens from marked board spaces
Unlocks cash, dice, and sticker packs
Why players watch their multiplier
You'll quickly notice that this event rewards patience. Some players burn through dice the second they get them. Others slow down and save bigger multipliers for moments when the board looks friendly. Neither way is perfect, but the Wiggum space makes that choice feel sharper. If you're low on dice, a lucky bribe can keep the session going. If you're already stacked, it can push you into another milestone run. That's the fun bit. It doesn't feel like a boring bonus screen. It feels like the board has shifted under your feet.
Milestones, tokens, and sticker hunting
The event isn't only about Chief Wiggum. The D'OH PLOW milestone track gives players another reason to keep circling the board. Landing on selected spaces earns event tokens, and those tokens build toward rewards in order. Cash helps with upgrades. Dice rolls let you stay active. Sticker packs are the real tease, though. Pulling a Real Estate Agent sticker with Homer or a Such a Tool sticker with Ned Flanders gives the crossover a bit of personality. It's not just numbers going up. You're filling pages, chasing missing cards, and hoping the next pack isn't another duplicate.
Making the most of the Springfield board
The best approach is to treat the event like a set of small chances rather than one massive jackpot. Watch your dice count, raise your multiplier when the board position makes sense, and don't ignore token spaces just because Wiggum is getting the spotlight. Players checking Monopoly Go Partners Event buy options are usually trying to stay active through these limited-time windows, and that makes sense when rewards are tied to timing, luck, and steady board movement.
Diesen Beitrag melden
Mit Zitat antworten
